Will there be any 5kg rolls of Prusament?
Joni the great
(@joni-the-great)
Will there be 5kg roll of prusament? It would be great for long prints and production runs.
Anyone else into this? I think it would be great!
Postato : 17/11/2018 1:49 am
Utenti
Re: Will there be any 5kg rolls of Prusament?
No anouncement. I suspect that they need to get a stable supply of the 1KG rolls first.
Postato : 17/11/2018 2:36 am
JMcK
 JMcK
(@jmck)
I remember a video that showed the Prusa Farm, which said they use 2Kg spools. If ever there was a use case for huge spools it’s there. So I’d imagine there’s a reason for not using them in the farm. Just guessing here: I’d imagine the Printer would have a rough time pulling filament off a spool that size. It may not be possible or reliable to use a 5Kg spool. Meaning the non geared extruder stepper May not produce enough force to turn a 5kg spool.
When someone asks you if you're a god, you say, "YES!"
Postato : 18/11/2018 7:43 pm
Joni the great
(@joni-the-great)
So your saying they are selling 2kg spools already? Or were they just talking about doing it in the future?
Postato : 19/11/2018 6:56 pm
Utenti
They have sold 2kg spoils of orange PETG.
Postato : 19/11/2018 7:30 pm
Laird Popkin
(@laird-popkin)
I bought an orange 2 kg spool and it's nice not to have to worry about reloading - nice material!
I've used up to a 10 kg spool before, and it worked fine. The main trick was hanging it over the printer on a steel rod, so the spool spun fairly easily (by slipping, no bearings, etc.) and the printer was pulling filament down. Though not many places sell 10 kg spools...
Postato : 20/11/2018 3:51 am
Dewey79
(@dewey79)
Another reason for the MMU 2.0 maybe if you are concerned about running out of filament and the sensor is not working properly.
Postato : 21/11/2018 5:03 pm
Peter L
(@peter-l)
I once bought a 30lb spool of filament (about 13.6kg). It worked just fine, and I used it all up eventually, but it was definitely a nuisance. Large filament spools take up a lot of space, you need special spool holders for them, and I generally don't think it's that great of an idea except under special circumstances.
But there were zero issues pulling the filament off the reel. I made a spool holder that had a shaft through the middle of the spool and a pair of bearings on either end of the shaft and it was fine. The printer was easily able to pull the filament.
Postato : 24/11/2018 3:10 am
