Why was my model deleted from Printables?
djos_1475
(@djos_1475)
Why was my model deleted? I modelled this from scratch and even included the STEP file for others to use!
Yes, my design was inspired by another design, but it was not a clone / remix. Please re-instate it!
I also have an extended version which I had gotten around to publishing:
Respondido : 21/01/2023 2:51 am
Hello
(@hello)
RE: Why was my model deleted from Printables?
Not sure maybe re post it and if any one reads this that can do somthing i filled out the survay got 50 prusa meters couple of days later they dissapered
Respondido : 21/01/2023 3:19 am
1 les gusta
djos_1475
(@djos_1475)
I've reported the person who I believe reported me, so I'll see if that gets anywhere first.
Respondido : 21/01/2023 3:25 am
PjotrStrog
(@pjotrstrog)
While designed from the ground up, it does seem your model is derived from the other uploader’s  model. I see many uploaders labeling their models as remixes even if those are built from the ground up. I’ve done the same. It has absolutely no downsides doing so and you prevent confusion. It also gives props to the people you got your inspiration from.
I do think that prusa should give uploaders the chance to fix their page before deleting it entirely. Putting it in Draft mode would be a good way to do this.
Check my designs
Respondido : 21/01/2023 9:59 am
1 les gusta
djos_1475
(@djos_1475)
With some designs you have physical constraints that simply can’t be avoided, in this case you have the BlueSCSI board and the Mac SE expansion slot.
 As a result, any designs will have distinct similarities.
I even mentioned that my design was inspired by the original.  I just find this whole thing distasteful.
Esta publicación ha sido modificada el hace 3 years por djos_1475
Respondido : 21/01/2023 10:14 am
djos_1475
(@djos_1475)
just to give sims idea of the physical constraints: this board is tiny and so is the expansion slot.
Respondido : 21/01/2023 11:01 am
towlerg
(@towlerg)
Perhaps trademark/tradename violation?
Respondido : 21/01/2023 3:12 pm
1 les gusta
djos_1475
(@djos_1475)
If that were the case, then all items with Macintosh in the name would have been removed, not just my model.
Respondido : 21/01/2023 10:14 pm
3Delight
(@3delight)
Moderador Moderator
I don't have any contact with the Printables moderators but I can see where they may have felt it was 2 similar looking to PotatoFi's version.  Why didn't you make it more different?  Live mount the car towards the left of the face plate, change the SD card symbol, to be honest it just looks like PotatoFis version with "BlueSCSI" on it instead of their symbols.
Bare in mind that just because you modelled it from scratch doesn't mean it's not a copy of someone else's, the overall look is copyrightable to me it is too similar.  For example if you made a cup that looked like a LEGO cup that LEGO uploaded but changed the word LEGO on the base to MINE it wouldn't make any difference that you modelled it yourself, it would still be a breach of the terms and conditions... Remixes are OK, but remodels aren't.
Respondido : 21/01/2023 11:40 pm
Which could easily be the case if Apple cared to pursue it. Just try to post anything with Lego in it…
Having said that, no idea if there's a trademark issue here because BlueSCSI looks like open source and not protected.
Respondido : 21/01/2023 11:53 pm
1 les gusta
djos_1475
(@djos_1475)
@3Delight Look closely, my micro SD card symbol IS different. There are a lot of details that are not the same, eg I didn’t bother adding holes for the mounting spare screws.
I also put a lot more effort into reducing overhangs to reduce bridging to make it easier to print. I designed in M3 knurled heat set nuts instead of screwing into nuts that drop in from the top.
PFI vs Mine:
Esta publicación ha sido modificada el hace 3 years 2 veces por djos_1475
Respondido : 21/01/2023 11:57 pm
djos_1475
(@djos_1475)
Posted by: @fuchsr
Exactly, it’s an open source project.
https://github.com/erichelgeson/BlueSCSI
Respondido : 22/01/2023 12:01 am
