why prusaslicer make so many travel vs cura 4.0.0 ?
marcottt
(@marcottt)
I'm working on a part  where the body is more or less an "U" extruded...  prusaslicer make a lot of travel and this is a problem because wall are very thin (0.8mm)  and these travel i'm sure will corrupt the edge, also in high there is a stupid series of travel and at the end is possible to see trought the rectangular hole a lot of travel in the base area.... cura 4.0.0 same setup did not make all this travel move.... :
cura:
as uo can see prusaslicer make a lot of useless travel in this case corrupt the thin wall edge.
There is a way to change the tipe of path ?
thanks
Marco
Attachment removed
Posted : 02/06/2019 9:32 pm
RE: why prusaslicer make so many travel vs cura 4.0.0 ?
You can try changing seam location from closest to rear; and there's an option to limit moves so they don't cross perimeters, though I suspect that won't help you model.
Going forward: when you post images, please change the Link To setting from None to Media: this allows readers to zoom in to the full res image.
Posted : 03/06/2019 5:20 am
marcottt
(@marcottt)
thanks @tim-m30, tried each option but result are worse, now there is also a new diagonal travel path....
(this attach as media, think is ok)
Posted : 04/06/2019 3:17 pm
