Where is it, or what?!..
Luis Alegría
(@luis-alegria)
Hello guys. look, when I slice using patterns as for example: helbert curve for surfaces, I was sure there was the option for: all upper surfaces, but now that option is nowhere... wt... help please or in 5 minutes I´m going to some bridge.. 🙏
Opublikowany : 08/04/2024 10:29 pm
JamieC1
(@jamiec1)
RE: Where is it, or what?!..
If you can’t find the option for applying a Hilbert curve pattern to all upper surfaces, check the software’s help guide, make sure you’re using the latest version, look carefully through all the settings, and if needed, contact customer support for help. Software features can change, but they’re usually still available in some form.
Opublikowany : 09/04/2024 10:09 am
Luis Alegría
(@luis-alegria)
RE: hmmm
Ok JamieC1, I´ll be checking that, thanks for the help. 💙👉
Opublikowany : 10/04/2024 12:14 am
vhubbard
(@vhubbard)
Infill; Top Fill Pattern, "Hilbert Curve" is listed in the options.
The search function in the slicer can find the paramters that are being set, but does not search based on the answer.   "Top Fill" is found, but not "Hilbert".
Your not crazy, "Hilbert Curve" or any of the other Top Fill options are not described in the help documentation either.    Help documentation still has a long way to go.
Opublikowany : 10/04/2024 1:12 pm
