What's the best way to print this?
Poodadoo
(@poodadoo)
This one has me stumped for the best way to configure this to print.  I'm using PrusaSlicer 2.7.0 and I am reasonably new to 3D printing but I'll be damned if I can figure out how to lay this on the bed and proper support settings, etc.
Would love some feedback.
Permatrack Roof Pitch 135.stl
Best Answer by Neophyl:
I'd print it like the bottom one but with less support. Those towers on the right aren't needed at all.  Just define the enforcer for the areas that do need it and everything else will print fine.
With good bed adhesion I wouldn't even use a brim but as I don't know what printer you are using I added one for the example.
Example project attached
Veröffentlicht : 07/12/2023 8:09 pm
RE: What's the best way to print this?
Can't access it. Access rights. Please don't use a third party site, zip compress the file and use the attach file button to upload it here.
Veröffentlicht : 07/12/2023 10:17 pm
Poodadoo
(@poodadoo)
I don't see an "attach file" button.  I see an Add Media button but it will not allow attaching of .stl files.
If you'd like to show me the button you are referring to, I'll happily attach the file... But, in the meantime, I've adjusted the permissions on the file on my google drive.
Veröffentlicht : 08/12/2023 1:16 am
'Attach file' is below the text input window, on the left hand side.
STL's need to be ZIP COMPRESSED. before the  forum will allow them to be attached.
Veröffentlicht : 08/12/2023 2:08 am
Poodadoo
(@poodadoo)
It's a bit misleading because it says media but I zipped it... Let's see if it works.
Veröffentlicht : 08/12/2023 2:12 am
_KaszpiR_
(@_kaszpir_)
This is quite interesting - it really depends on what is your priority?
- time
- used filament
- structural strength
- quality of specific walls?
Choose wisely! Below some screens with arbitrary filament selection, but notice bottom right corner about used filament and time spent.
Above is Inverted bridge, probably more filament wasted to supports than model itself 😀
Also, that print time is insane!
Above is side print, quite a lot of supports as well.
Above is 'bridge', could be tweaked to use less supports by painting only on specific places and ensuring printer can make decent bridges.
Half of the print is over supports, though.
Least supports, but those support towers on the right can turn into a nightmare and fail. Yet maybe your printer may not really need them?
Personally I would go with the 'bridge' because base is full of supports and less prone to things going bad, after that it prints other fragments.
Uses a bit more filament for supports but prints the quickest.
Veröffentlicht : 08/12/2023 10:24 pm
jsw
 jsw
(@jsw)
If this were mine, I would do it pretty much the way the first example is shown, assuming the inside of the model is not intended to be visible.  'Greasy side down.' As in position break-away supports so the blemished surfaces will not show.
Veröffentlicht : 08/12/2023 10:38 pm
Veröffentlicht : 09/12/2023 2:09 am
Poodadoo
(@poodadoo)
@Neophyl wins!  This printed flawlessly and thanks for including the sample file.  Question though... (from a learning point of view) -- what is an enforcer and how did you get the supports to print this way?  Every time I tried it wanted to print supports for the top part.  This setup printed flawlessly on my Ender 5 S1
Veröffentlicht : 09/12/2023 12:57 pm
