What would you like to see in the 8-bit firmware?
Seite 16 / 20
RE: What would you like to see in the 8-bit firmware?
You can edit your end gcode block in PS to unload the filament if that is what you want to do every print.  No change required to the printer firmware.  Just add in a large extruder negative value and it will pull the filament out of the hotend for you.  Be a pain though if you want to print something else with the same filament afterwards.  Thats the point of the custom gcode areas, you the user can make it work how you want.
However I should point out that at least on the MK3 printers (which this thread is about changes to) that Prusa expects the user to manually remove the filament immediately on unload as the thin string can still be between the bondtech gears.  So if you go to remove it afterwards there's a likely hood that the thin string breaks and remains in the gears/ptfe tube.  This could potentially cause issues with loading new filament.
In summary unattended filament unloading is not recommended.
Veröffentlicht : 17/03/2022 9:51 am
Karfi
(@karfi)
Thank you for your Answer.
I didn't pay attention to that and of course it wouldn't be good
Veröffentlicht : 17/03/2022 1:25 pm
luk
 luk
(@luk)
Preheat ready beeping would be great! 🙂
Veröffentlicht : 21/03/2022 6:44 pm
Posted by: @luk
Add that to your start gcode in your Prusa Slicer profile and you can have a sounds when it reaches the preheat temps.  Doesn't require any firmware change.
Veröffentlicht : 21/03/2022 7:35 pm
Go to https://help.prusa3d.com/en/article/prusa-specific-g-codes_112173. What you're looking for is M300. As neophyl said, put it in the startup custom gcode in PrusaSlicer.
Veröffentlicht : 21/03/2022 7:46 pm
Artur5
(@artur5)
I'd like that the profiles for the flex steel plates would save not only the Z first layer but also the bed level corrections. I own three plates and each needs different values for right-left-front-rear, so I have to keep a record of these values and change them every time I switch plates.
Veröffentlicht : 22/03/2022 9:30 am
David H. Brown
(@david-h-brown)
Posted by: @neophyl
Posted by: @luk
This recommendation doesn't make sense to me. I think it would work only if I'd started a print... but if I were printing, I wouldn't need a beep because as soon as the temperatures are reached I'll hear the printer start to measure the bed.
The real value of beeping when preheat is reached would be when selecting a preheat from the control panel, e.g., to load filament. Especially with the 12V Mk 2, getting the nozzle to temperature can take long enough that I'll turn my attention to something else and forget about the printer.
https://www.printables.com/@DavidHBrown_24313https://www.thingiverse.com/davidhbrown/designs
Veröffentlicht : 22/03/2022 12:39 pm
luk
 luk
(@luk)
No, It would be great to have beep ready without any gcode print start.
I allways first preheat, clean nozzle, and then start gcode printing.
Veröffentlicht : 23/03/2022 7:00 am
Chris
(@chris-24)
I'd like to see the sensor readings (PINDA, FINDA, Filament) all the while. Not onlly when selecting "Support|Sensor Info". And it should be a permenent reading, not only while printing, also while loading/unloading filament, calibrating, ... It could be realised as a binary display, using only one character in lets say the right topmost corner of the display, with 0 meaning all sensers off, 1, 2 and 4 resp. for the single sensors up to 7 for all sensors on.
Furthermore I ask for correcting the flaw, that sometimes the sensor info from the MMU ist not available.
Veröffentlicht : 05/04/2022 11:11 am
This would be an alternative selfmade solution:
With the LED solution, the status of the sensors is constantly visually detectable.
wbr,
Karl
Veröffentlicht : 05/04/2022 7:20 pm
Crab
 Crab
(@crab)
I haven't read all 16 pages, but with many users using OctoPrint, some integration would be nice.. like:
a) the ability to track printer hours and filament usage no matter the origin of the print (SD or serial port)
b) some recording of the current X,Y,Z position after each step so if power fails, Octoprint could create an option to start a print at a particular spot.. I just lost a 9 hr print to a 2 second power hiccup. So the firmware should know when  print job finished successfully, and so can flag an incomplete print job upon power up.. ,.. Maybe this exists.. but haven't come across it in my research to resume from print failure.
Veröffentlicht : 12/04/2022 1:51 pm
Chris
(@chris-24)
An LED on the sensors back would tell you the state of the sensor. But it won't tell you, what the computer thinks about it. You will not know, e. g. when a cable is broken...
Diese r Beitrag wurde geändert Vor 4 years von Chris
Veröffentlicht : 17/04/2022 9:28 am
Weinberger
(@weinberger)
Hello cwbullet .
I am new to the forum. Excuse me, I would like to know how this changes the situation.
Veröffentlicht : 19/04/2022 6:54 am
doctorg
(@doctorg)
+1 for the 170 degree nozzle temp during bed leveling. I also would like to see a quicker way to return to the home position after a print without having to scroll two menus deep.
Veröffentlicht : 22/04/2022 12:15 pm
Posted by: @doctorg
Just FYI: To truly customize gcode in firmware will probably require a controller board with more capabilities than the current 8 bit board used on the Mk3 series. You can do those things today with some tweaks to your printer start and end gcode if you don't want to wait. I've got some notes on this topic here if you're interested.
Veröffentlicht : 22/04/2022 3:06 pm
doctorg
(@doctorg)
Yeah, I could do it in gcode, just thought it would be a nice upgrade.
Veröffentlicht : 23/04/2022 12:42 am
Steve DeGroof
(@steve-degroof)
It's a minor thing, but it'd be nice to have the "time remaining" display switch from hours and minutes to minutes and seconds once the time drops below one hour.
Veröffentlicht : 21/05/2022 10:18 am
Steve Lelievre
(@steve-lelievre)
I'd like a configuration option for choosing to have the print head rise to maximum height after every print. It would give more clearance for removing the print sheet and also make it easier to check/clean the hot end.
Veröffentlicht : 14/06/2022 2:06 am
Antonio
(@antonio)
Mitglied Moderator
Posted by: @steve-lelievre
i'm pretty sure you can do that modifying the end-gcode from the printer profile 😉
not sure of the exact command though
I'm not an expert. Ma parlo anche italiano 😉
Veröffentlicht : 14/06/2022 9:03 am
jsw
 jsw
(@jsw)
I used to keep a simple .gcode file on the disks to raise the print head and move the build plate forward.
I quit using that, figuring it was less time and fewer clicks to simply press the control knob and spin it.
Veröffentlicht : 14/06/2022 9:06 am
Seite 16 / 20
