What chemical can be used to "glue" PLA?
gregnier
(@gregnier)
I not only need to "bond" two pieces of PLA together, but I need a substance that will attack and dissolve PLA surfaces so they can be attached to each other. In other words, as if they were melted together.
Veröffentlicht : 10/03/2020 6:08 am
RE: What chemical can be used to "glue" PLA?
3D Gloop has a PLA formula that will work. Nasty stuff, so use it with care.
Veröffentlicht : 10/03/2020 7:23 am
Stefan
(@stefan-2)
I have had very good results with "Schwanheimer Industriekleber". The "usual" thin liquid Nr 100 is fine for exact fits with no gaps (hardens in absence of oxygen under pressure), while the more viscuous gel Nr. 300 does well with gaps. They also offer a "Special Filler" powder, which is to be wet with their Nr 100 glue and quickly hardens to some very hard solid material, bonding "everything to everything".
I guess it's some cyanacrylate.
Veröffentlicht : 10/03/2020 8:51 am
LuClass
(@luclass)
This is my Favorite for PLA.
Look in your Country ......
LG Thomas
(Wood) CTC i3-Clone, (Yellow) i3-Steel DIY, (Green) Original Prusa i3MK3(s)+MMU2.0, (Red)DICE, (Blue) Anycubic Chiron, (Grey) Qidi X-Max, (Orange) PrusaXL 5T
Veröffentlicht : 10/03/2020 9:40 am
Bodo
 Bodo
(@bodo)
Posted by: @gerard-r2
If you're looking for a substance that is to PLA (and PETG btw) like Acetone is to ABS, you might want to look at Dichloromethane - but caution: this isn't as available and also classified as health hazard. It does melt ABS and acrylics too, so it can be used to melt printed parts with PMMA or PC as well. Normally, this is not sold to consumers. I got mine from abroad.
Veröffentlicht : 10/03/2020 10:47 am
Matteo Cristini
(@matteo-cristini)
Check out this video: link
Apparently you can bond two PLA parts by brushing some acetone on both pieces. I haven't tried it myself though.
Veröffentlicht : 10/03/2020 11:21 am
Matteo Cristini
(@matteo-cristini)
Judging from the comments though, it might weld only some particular PLAs - might be worth a try anyways
Veröffentlicht : 10/03/2020 11:33 am
Mary Tillios
(@mary-tillios)
Options are too sophisticated with hazardous substances. You can try the glue, but the result will be normal. It’s better not to play with carcinogens, you never know what this will lead to.
Veröffentlicht : 10/03/2020 12:31 pm
j1m1sh
(@j1m1sh)
I've had good luck with SCIGRIP 16 10315 Acrylic Cement.
https://www.amazon.com/SCIGRIP-10315-Acrylic-Cement-Low-VOC/dp/B003HNFLMY
Jim
Veröffentlicht : 10/03/2020 1:29 pm
Birdman2010
(@birdman2010-2)
Posted by: @j1m1sh
Jim
I like this stuff as well!  It "melts" the PLA and bonds it.  Works very well.
Veröffentlicht : 26/03/2020 4:36 pm
vintagepc
(@vintagepc)
Mitglied
Posted by: @rickjbird
Posted by: @j1m1sh
Jim
Most acrylic cements contain dichloromethane, which will also melt and bond PLA.
Veröffentlicht : 26/03/2020 6:50 pm
Steve
(@steve-3)
I use two part epoxy with a few threaded rod pins to give extra surface area. Have not heard of any failures in any of my clock designs and they have 6-8 pounds of force trying to pull the object apart. I use 6-32 threaded rod at least 1" deep into each part being joined.
Steve
Veröffentlicht : 26/03/2020 8:22 pm
