UX feature request for the calibration wizard
Mounting Man
(@mounting-man)
Hello community,
last time I had some problems with the heatbreak, so I head to re calibrate the whole system a lot. ( I moved the Z axes manually to clean the nozzle)
Today I changed the heatbreak and after assembling printer head, I started the calibration wizard.
At the calibration is one step the head moves down to the heatbed in small steps (put a sheet of paper between the nozzle and bed). And if the Nozzle hit the paper or the bed abort instantly.
But I case the nozzle hit, what have I to do now? The next step is missing, if I start again the nozzle is hitting the bed again so this couldn't be the solution I think.
Now her comes  my idea, is it possible to complete the instruction at the wizard - if the nozzle hit the bed abort instantly an re adjust the P.I.N.D.A. Sensor like the description in the manual. (re adjusting was the solution:) )
I had these problem and I was really frustrated because I did not have any clue how I can fix the problem. With a little bit of luck I found a hint in the forum, but I wasted a lot of time and with some words more I would have fixed the issue in 1 minute.
I'm not really sure the same issue consist with the English language (or other languages) because I use the German language. But my idea was to post here, because her is more going on and maybe some other guys can give a feedback from the other languages. And who knows, maybe with one of the next versions the UX feature is included?
Best regards
K
Publié : 19/01/2020 6:42 pm
