Undesirable extra brownish filament on top surface when using Ironing in PS 2.3
Hi, I have tried the default Ironing settings and also changed the Flow Rate to 15% and 25%. Line spacing is kept at default. However, there are always brownish extra filaments being deposited on the top layer. How do I prevent that from happening again?
Opublikowany : 25/01/2021 1:58 am
RE: Undesirable extra brownish filament on top surface when using Ironing in PS 2.3
Possibly reduce the flow rate. It sounds like there is filament building up on the nozzle and getting pulled back into the print. Pictures of the problem you are experiencing might help.
Opublikowany : 25/01/2021 8:44 pm
