TPU print stringing
I'm using "Ooznest TPU Bend", it's ok if you print only one object on the bed.
If you run it at 15mm/s it does not jump out the side - in fact it will run faster than that - but don't be greedy.
I use their suggested profile. I do not use retract. Z hop is on. I have an enclosure, but I leave the door open - it does not seem to matter. The bed is 50-60ºC and the nozzle 240ºC.
Stringing is a real pain. So this means that if you print multiple objects or objects with large voids - you will have a hell of a clean up job.
Vase mode prints perfectly as the head never lifts off.
Also support material is hard to remove - but often pulls off without scarring, despite having to man handle it.
Sometimes it is a real pain to remove.
I often print pods for quads/racing drones and I smooth them with a heat gun which can look sweet - but it's really easy to overdo.
This pod is printing atm - it's really hard to photograph but the texture is lovely.
The only issue is the stringing ( and the globby stuff on this print due to the head having to travel through a no printing part ).
I'd love to get rid of the stringing. ( This looks 5x better in real life - the texture is sweet ).
RE: TPU print stringing
Here is a before and after pic of the stringing - the after pic is not as good - it looks really good in real life. It only needs to be functional.
omg! this looks so neat and crafty.
In the file section in the Prusa Community on facebook there is a tpu file I have used called pp something and there was no stringing on pieces I made.
Dry your TPU. Stringing gets worse as it absorbs more moisture.
