Tools: What do you recommend?
Pagina 17 / 17
Michaël Fortin
(@michael-fortin)
RE: Tools: What do you recommend?
My personal recommendation for a heat gun is to get a butane torch instead.
Strings shrink instantly and are easily removed afterwards. I used a heat gun before and had issues with it melting and deforming my prints because you need to keep it pointed at the print longer to get rid of strings.
Postato : 21/10/2023 10:37 pm
1 persone hanno apprezzato
I agree with @michael-fortin
A handy device would be for example this one:
(gastro burner)
wbr,
Karl
Postato : 22/10/2023 2:16 am
Jeggo
(@jeggo)
For just melting of some small artefacts, the heat gun is efficient enough. I would recommend a battery powered heat gun like this one:
https://www.einhell.de/p/4520500-te-ha-18-li-solo/
For smoothing a surface, you will probably need a gas torch, as the heat gun can not supply the heat fast enough. As mentioned a kitchen gas torch works fine and has dual use 😉
Postato : 22/10/2023 8:14 am
Stu
 Stu
(@stu-4)
Utenti
you mean welding tungstens for TIG ?
That’s brilliant!!
Postato : 26/10/2024 3:46 pm
vhubbard
(@vhubbard)
A deburr tool.   Good for elephant foot, brim removal and edge clean up. also allen wrench sets
Postato : 27/10/2024 8:52 pm
Pagina 17 / 17
