Tips for moving Printer?
danilsjames121
(@danilsjames121)
Hello everyone,,
Has anyone here had any personal experience moving their printer?
Am moving mine a few states away.  I think it will get VIP treatment in my car, but I also have other expensive equipment that needs that space.
I think I will plan to upgrade it (MK3 to MK3S) after the move, so hopefully any deformations will get worked out while I do the upgrade.
Does anyone else have advice on carrying and transportation?
Thank you!
http://tradevenue.se/
Napsal : 24/12/2019 2:20 pm
K7ZPJ
(@k7zpj)
RE: Tips for moving Printer?
Immobilize the x and y axis using zip ties or use string so they don't move/bang around during transit.
Once you are ready to set it back up, do  a factory reset and run through the calibration wizard.
To reduce troubleshooting headaches, make sure the printer is working right before doing the upgrade to MK3s.
Napsal : 24/12/2019 11:17 pm
3Delight
(@3delight)
Moderátor Moderator
I know it might seem obvious but make sure you remove the filament roll from on the printer! If you can put it in a box and pack it round with packing paper or offcuts of bubble wrap and mark it FRAGILE, and THIS WAY UP.
Napsal : 25/12/2019 6:19 pm
