thermally conductive filament, mk4s
Jim
 Jim
(@jim-21)
I'm trying to print heat sinks.  Are there recommendations for thermally conductive filaments?  I'm using a mk4s.
Opublikowany : 13/01/2026 3:18 pm
RE: thermally conductive filament, mk4s
The only one I'm aware of is this: https://tcpoly.com/purchase-ice9-materials/
Is there a reason you need to print a heat sink as opposed to milling it from aluminum?
Opublikowany : 15/01/2026 2:01 am
1 ludzie polubili
That thermally conducting TPU @hyiger found is interesting. But at best, you could use it to print thermal pads -- thin flexible layers to establish thermal contact between an object and a proper metal heatsink. It's thermal conductivity is only 6 W/(m*K), whereas aluminum has > 200 W/(m*K).
I'm afraid wanting to 3D print a heatsink using FDM is a fool's errand. You could probably produce something useful via SLS (laser sintering) with metal powder -- if the geometry demands 3D printed parts; otherwise classical milling should be cheaper.
Opublikowany : 15/01/2026 7:28 am
jan.d.slay
(@jan-d-slay)
Posted by: @hyiger
Depending on how much heat the heat sink has to dissipate, I would prefer to use metal.
Opublikowany : 15/01/2026 7:43 am
Jim
 Jim
(@jim-21)
No question metal is better, but I'm making a contorted shape that is hard to mill.
Opublikowany : 15/01/2026 10:23 pm
You can try copper filled filament - it definitely has a greater heat capacity but it doesn't conduct heat as well as straight metal.
Opublikowany : 16/01/2026 12:16 am
_KaszpiR_
(@_kaszpir_)
Print 3d model and use it to create a cast for molding?
Opublikowany : 16/01/2026 6:40 am
