Surface Issues on Large Prints (PETG, 0.8mm Nozzle)
Darsh506
(@darsh506)
Hello all,
I'm new to the forum, although I’ve been lurking for a while and learning a ton from the advice and tips posted here – big thanks in advance to all the contributors and gurus!
While I don’t have a Prusa, I’m hoping someone here might be able to help me dial in my Creatbot D1000. It’s been a bit of a nightmare out of the box, but I’m determined to make it work. I’ve already made some key improvements – particularly to the bed setup.
The print volume is 1000 x 1000 mm, split into four 500 x 500 zones. Unfortunately, the build quality isn’t great, and bed levelling has been a major challenge. I’ve now added a 4mm thick tempered glass sheet, which has helped tremendously – I can actually get prints going now without immediate failures, which is a huge step forward!
I’ve just completed a large print, and while it finished successfully, I’ve noticed serious issues with the top surface quality. There are missing areas, visible bumps, and poor finish overall – although oddly, some other areas of the print look fine.
Here are my current print settings:
Nozzle: 0.8 mm
Layer height: 0.32 mm
Infill: 15%, Cubic Subdivision
Perimeters: 2
Top solid layers: 3
Bottom solid layers: 2
Speed: 60 mm/s
Retraction: 2 mm at 40 mm/s, minimum travel after retraction 1 mm, “wipe while retracting” enabled
Material: PETG
Temp: 240°C nozzle / 70°C bed
Filament diameter: 1.75 mm
Extrusion multiplier: 0.95
Extrusion width: 0.96 (calibrated via test prints)
If anyone has experience with large-format printers, PETG settings, or issues with inconsistent top layers, I’d really appreciate your thoughts. I’m not sure whether this is under-extrusion, cooling, or something else entirely.
Thanks in advance!
Opublikowany : 12/05/2025 12:04 pm
BaconFase
(@baconfase)
RE: Surface Issues on Large Prints (PETG, 0.8mm Nozzle)
Looks like generic pillowing to me. So add more top layers and maybe increase the infill density some.
Opublikowany : 14/05/2025 9:20 pm
Agreed, there is an underlying pattern to the flaws that suggest it is related to the internal fill structure.
More top layers, perhaps combined with a fill that increases density near the top should fix it.  Eg, try adaptive cubic fill.
Opublikowany : 15/05/2025 12:03 am
