Support Material Not Staying In Place
ARAMP1
(@aramp1)
I'm not sure what might need to be changed to fix this.  My support material in the larger gap isn't staying in place?  I have no issues with the smaller gap on the right side.  Maybe slow it down?
Veröffentlicht : 11/07/2023 1:53 pm
ARAMP1
(@aramp1)
RE: Support Material Not Staying In Place
I might just try it again with the organic supports.
Here's what I'm trying to print.  Using PETG.
Veröffentlicht : 11/07/2023 6:22 pm
Do you NEED supports? Looks like the printer should be able to bridge those windows just fine.
Veröffentlicht : 11/07/2023 8:04 pm
ARAMP1
(@aramp1)
Posted by: @fuchsr
I don't know...just wanted to error on the side of caution.  Guess I could give it a shot.
Veröffentlicht : 11/07/2023 9:46 pm
Robin_13
(@robin_13)
Do a test print with the opening size before trying the full print.  Default MK3+ settings and Prusament PETG, I got decent bridging to 20mm.  Some changes and I can print 50mm with some stringing on the bottom.  I just created a simple test for that purpose.
Veröffentlicht : 14/07/2023 5:38 am
ARAMP1
(@aramp1)
This is the warning I get when I run the slicer without supports....
Veröffentlicht : 22/07/2023 3:57 pm
ARAMP1
(@aramp1)
It's basically a problem with the support material.  Her are a couple prints I've started.  The support material is not sticking to the smooth part.  The one on the left I decided to switch to organic and still had the same issue.
I decided to flip the block so the support material could print on the bed and here was my first result.
I'm retrying it again now.  I made some adjustments to the support material making it thicker, lowering the contact distance, lowering the pattern spacing and making the branch diameter larger.  If this doesn't work, I might try slowing it down.  I'm not sure what else to do.
Veröffentlicht : 22/07/2023 4:12 pm
_KaszpiR_
(@_kaszpir_)
can you print it vertically (so that L3 will stand vertically), or is the model too high for that?
Veröffentlicht : 23/07/2023 11:11 am
ARAMP1
(@aramp1)
So close!  I think I'm going to lower the support material contact distance to zero.
Posted by: @_kaszpir_
Possibly.  I have a couple other pieces that are similar that I probably won't be able to, so I'm hoping to figure this out.
Veröffentlicht : 23/07/2023 2:42 pm
