RE: Support Material Not Staying In Place
Do you NEED supports? Looks like the printer should be able to bridge those windows just fine.
I don't know...just wanted to error on the side of caution. Guess I could give it a shot.
Do a test print with the opening size before trying the full print. Default MK3+ settings and Prusament PETG, I got decent bridging to 20mm. Some changes and I can print 50mm with some stringing on the bottom. I just created a simple test for that purpose.
It's basically a problem with the support material. Her are a couple prints I've started. The support material is not sticking to the smooth part. The one on the left I decided to switch to organic and still had the same issue.
I decided to flip the block so the support material could print on the bed and here was my first result.
I'm retrying it again now. I made some adjustments to the support material making it thicker, lowering the contact distance, lowering the pattern spacing and making the branch diameter larger. If this doesn't work, I might try slowing it down. I'm not sure what else to do.
can you print it vertically (so that L3 will stand vertically), or is the model too high for that?
So close! I think I'm going to lower the support material contact distance to zero.
Possibly. I have a couple other pieces that are similar that I probably won't be able to, so I'm hoping to figure this out.
