Suitable filament for printing a high torque shaft coupling
ThePartsGuy
(@thepartsguy)
Due to some obscenely long lead times provided by my hydraulic equipment vendor, I'm doing some research on what printer/filament combination would be necessary to print a replacement spider coupling for a hydraulic pump/motor combination. The math says that the coupling would have to withstand 900 ft-lb of torque. There is a 20 hp motor on one side of the coupling and a rotary vane pump on the other. The coupling would have a 1" ID and use set screws to tighten the coupling halves to the shafts. Any recommendations would be appreciated.
Napsal : 27/11/2025 8:01 pm
Steve
(@steve-5)
RE: Suitable filament for printing a high torque shaft coupling
Your biggest challenge is going to be printing orientation so that forces are not aligned along layer lines, I would recommend designing so that it is printed at a 45 degree angle from the build plate.  Slant 3d and a couple other youtubers have videos about how to accomplish this.
As far as materials available to print at temperatures achievable by most consumer printers I would recommend either a Polycarbonate or Nylon.  The CF is not strictly necessary for strength but it makes the PC easier to print without warping.  The only PCCF I've used is Prusa's and that can be hard to find.  I have seen some good reviews for  YXPolyer PC-CF (on Amazon).  I have had good personal experience with Overture Easy Nylon as well.
Regards,
Steve
Napsal : 28/11/2025 8:40 pm
CyclonEngr
(@cyclonengr)
This is an interesting idea, however it seems quite challenging to replace what I’m guessing is a metal coupling with a 3D printed plastic alternative?  Depending on the consequence of a failure (or how much ‘life’ is required), you might get acceptable performance with a ‘low-cost’ consumer type of polymer FDM printer.  Without knowing the details of the coupling design (i.e. is it a splined/toothed or key way or tapered shaft), it’s difficult to know the likely cause of failure (or the area of highest stress).
If you have access to a fiber-reinforced printer, I think you will have a better chance of success . . .
Good luck!
Napsal : 28/11/2025 9:08 pm
Artur5
(@artur5)
Among the easily available filaments, printable at only 250c, my favorite is Fillamentum Nylon AF80 with aramid/kevlar fibers. Very strong, endures most chemical compounds and it’s extremely resistant to wear and friction.  I make BSP fittings of ¼" to ¾” with it and I never had one of them cracking, as it happened to me sometimes with other CF filaments. It has to be seen if it would replace successfully a big metallic part. As the other posters said, it depends a lot on the design of the model.  Anyway, a 20 Hp motor is no joke, so I’d be very cautious using a plastic part for this task.
Napsal : 29/11/2025 9:17 am
