Spool Size Question
JBinFL
(@jbinfl)
Spool Size Question
Hello All:
New user with Mk3 Kit which I assembled and have been printing very well for a week so far using the supplied Prusa silver spool. I have the printer in the standard configuration with the supplied spool holder on a table and have been very pleased with everything so far.
I know I want to print the Prusa LACK cabinet parts and assemble a cabinet. I purchased some Colorfabb PETG economy to print the parts. However, I made an error and bought a 2.2Kg Spool 😳 . It is too big to fit on the provided spool holder so I am kinda stuck for the moment. Once I get the cabinet built, it will not be an issue because I can print an adjustable spool holder for the top of the cabinet and be set.
I am not sure what I can do to use the PETG to print the parts and suggestions would be welcomed.
Can I just unspool a bunch and of the PETG and somehow use it unspooled 😯 😯 ? any tips on that?
Should I use up the Prusa Silver and somehow transfer some of the PETG to an empty spool? is there anything i need to be aware of if I do that?
Is there a way to use the 2.2Kg spool, like a part to print or something that will work with the standard spool holder?
The printer is in a great configuration and printing well from what I can tell right now, so I would like to keep it as it is without messing with anything and print all the parts for the cabinet in PETG before I do other adjustments that I plan to do when I replace the parts for the cabinet (heatbed cover, PSU support and planned belt tightening) and such.
thank you for any info / suggestions.
JB
Strange women, laying in ponds, distributing swords, is hardly a basis for a system of governance!
Posted : 08/09/2018 1:17 am
Phil
 Phil
(@phil-4)
Re: Spool Size Question
You can definitely use it unspooled. Just cut off a section and then let it hang off the provided spool holder somewhat loosely. In your Slicer it will tell you the approximate length you need. Add several meters just to be safe and then cut it and use it.
I've done it on several occasions with no issues. I bought a set of 5 meter loose spools in a variety pack and this is how I use them. I wouldn't recommend this for a 50 meter print or anything, but if you need 10 meters or so, you will be fine.
Posted : 08/09/2018 6:20 am
Neal
 Neal
(@neal-3)
Ya...what Phil said. But I do keep a few empty spools handy for loading some off another spool or the sample packs. JUST MAKE SURE YOU WIND IT WITHOUT TANGLES. Sorry to yell but that part is pretty important.
Neal
Posted : 08/09/2018 12:17 pm
Robin
(@robin-4)
I have the large spools now (2.3KG). I also wanted to Print the Lack enclosure parts and didn't know the 2.3KG spool was so big it would not fit the Prusa spool holder. I just set up some stepladders and G clamped a pole across to hold the spool until i had printed the parts.
I have modified this spool holder to fit the Lack enclosure. https://www.thingiverse.com/thing:3020026 It has bearings for the filament spool to sit on to allow less friction as the spool rotates and no chance of it falling off.
Posted : 08/09/2018 12:25 pm
Peter L
(@peter-l)
You can use almost anything as a spool holder as long as it turns relatively freely.
A broom handle sitting on two chairs is a perfectly workable spool holder.
If all else fails, put the spool on its end on a lazy susan.
Posted : 08/09/2018 2:18 pm
JBinFL
(@jbinfl)
phil.s6: Awesome. Thank you for the reply. I did see the approx length estimate and that is a good tip to add extra. I like it and is probably the simplest solution to get started.
Neal
Neal: Gotcha and thanks for the emphasis. Should I wind it tight to the spool like how it comes neat and aligned or loose but just make sure it is untangled? I noticed that when using the Prusa spool and the filament got to the ends where a new roll starts I would loosen one or two spool wraps by hand while it was printing to ensure it would not bind on feeding, but I only did one or two wraps to ensure it would not tangle.
Robin.a: Yeah, the spool actually hits the Y-axis frame because the hole in the spool is so large. That did not seem good nor like something I wanted to chance when I saw it. Oh, I like that modified spool holder. I will print that (in NGEN once I get it set up), it is handy. Thank you.
Peter: Thank you. The table I have the printer sitting on has they top of the Y-axis at 4'6" from the ground and so it will need to be taller than that which is why it did not initially dawn on me 😕 😕 However, I have thought of how I will work around with this method using some chairs and height adjustment items and I do have pole/handle that can be used.
Great suggestions all, and very fast. I appreciate it.
Posted : 08/09/2018 4:27 pm
Robin
(@robin-4)
The spool holder needs to be longer than the one on thingyverse. That one is for 73mm wide for small spools. I have altered it to 101mm wide for the larger 2.3kg spool. I'll put the files onto thingyverse when i have time.
Posted : 08/09/2018 5:30 pm
Neal
 Neal
(@neal-3)
I haven't had any trouble with it being loose wound. Unless you really crank up the speed and it starts to jerk as it pulls tight and then the spool turns. Usually the spools have a hole to put the first bit of filament in and hold it secure while you wind it. I don't really like those because they usually make the spool jump on the holder. Use a little tape to get it started and you should be good to go.
Neal
Posted : 09/09/2018 1:35 am
JBinFL
(@jbinfl)
Update
Thank you everyone for the help!!
I rigged up a temporary thing and started by unspooling an estimate of the meters required and put on the temp spool holder to start. It worked but required maintenance to ensure it would not tangle and I had an instance where I had to add filament on the fly as my estimate was off 😮 😮 😮 . Good times , good times. I then just used the spool directly on the rigged platform and it has been working superbly and I am almost through with the cabinet parts.
Attached pictures for others to have as a reference. - apparently you have to take pictures in landscape mode like a caveman or they show up sideways... apologies.
Unspooled setup
Spool Setup
PSU Brace
Posted : 13/09/2018 3:16 am
Neal
 Neal
(@neal-3)
Nice work. Just a suggestion though. If you are going to use loose filament don't secure the off end like that. You still want the filament to unroll even if not on a spool. A long unattended print and that will tighten on the rod holding it.
Neal
Posted : 13/09/2018 2:45 pm
Any body have a winding jig?
Posted : 13/09/2018 3:08 pm
JBinFL
(@jbinfl)
Neal
Neal: Thanks, yes I did experience that. I noticed the loose filament would create this ball like structure and since there was so much, it was not a problem because I was closely monitoring it as I feared a tangle-snag happening.. I do not plan to do that with larger prints int he future if I can help it.
Posted : 14/09/2018 12:19 am
