Slic3r different amount of shells in one print?
robert.t24
(@robert-t24)
Is there an easy way in Slic3r to change the amount of outer perimeter shells in one stp file/print? I want to start a print with 2 outer shells for the first millimetre then drop to one shell after that?
In S3D I can add an extra process at any height Or layer I wish and adjust most all printing parameters for that new process.
Any help sought here?
Opublikowany : 03/12/2018 10:30 pm
Jerry
(@jerry)
Look at using a modifier in Slicer
Ask how if you try
Opublikowany : 04/12/2018 1:16 am
Fabi
 Fabi
(@fabi)
Re: Slic3r different amount of shells in one print?
Yes you can quite easy with modifier meshes:
https://manual.slic3r.org/advanced/modifier-mesh
Opublikowany : 04/12/2018 12:07 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
Thanks for that link!
is there something that adds the Slic3r-PR fork info? I understand the 2 forks have diverged quite a bit
I did not even know there was a manual for Slic3r!
is there one for the Slic3r-PR fork? even a beta manual for the =PR fork would be a big help.
I would expect to find it at https://github.com/prusa3d/Slic3r/releases and there should be a PE fork for the wiki as well as the manual
the Page here seems to not be up to date with all the features New User Guide https://www.prusaprinters.org/slic3r-prusa-edition-beginners-guide/#_ga=2.84344540.413454282.1543938474-314787885.1542203104
the ideal would be a copy of this manual site with each page showing what is not in the -PR fork (perhaps with the deprecated text shown with strike through and the -PR fork done in an appropriate :geek:
Opublikowany : 04/12/2018 4:44 pm
Fabi
 Fabi
(@fabi)
Very good question!
As I know you have to collect the single pieces together from the release notes as heere for support improvements:
https://github.com/prusa3d/Slic3r/releases/tag/version_1.41.1-beta
or heere for new slow down algorithm:
https://github.com/prusa3d/Slic3r/releases/tag/version_1.39.2-beta
Opublikowany : 05/12/2018 1:46 pm
