Show and dismis UIAlertController in Swift 4
william.t18
(@william-t18)
I declared a global variable for UIAlertViewController for me to be able to show and dismiss it in different method inside my class. I displayed two kinds of alert: First, alert with button which will be displayed when an error is encountered or to display an information message. Second is an alert without button which will be displayed like a progress message mypremiercreditcard.
Here is the sample code:
private var alert: UIAlertController? // global declaration
private func showProgressMessage(sender viewController: UIViewController, message alertMessage: String)
DispatchQueue.main.async
self.alert= UIAlertController(title: "", message: alertMessage, preferredStyle: .alert)
viewController.present(self.alert!, animated: true, completion: nil)
private func showAlertMessage(sender viewController: UIViewController, title alertTitle: String, message alertMessage: String)
self.alert= UIAlertController(title: alertTitle, message: alertMessage, preferredStyle: .alert)
self.alert!.addAction(UIAlertAction(title: "OK", style: .default, handler: nil))
private func method1()
DispatchQueue.global().async
// some code here
self.showProgressMessage(sender: self, message: "Processing...")
// some code here
private func method2()
// some code here
self.alert!.dismiss(animated: false)
self.showAlertMessage(sender: self, message: "Done")
self.displayOtherViewController()
private func displayOtherViewController()
self.alert?.dismiss(animated: false)
if let viewController = self.storyboard?.instantiateViewController(withIdentifier: "Sample")
let view = viewController as! SampleViewController
view .modalTransitionStyle = .crossDissolve
self.present(view , animated: true, completion: nil)
In method2, displaying the alert again will take a few seconds to display, same with the view controller. What is the proper way to show and dismis the UIAlertController in Swift 4?
Napsal : 24/12/2018 7:59 am
