Show and dismis UIAlertController in Swift 4
Edward1058
(@edward1058)
I declared a global variable for UIAlertViewController for me to be able to show and dismiss it in different method inside my class. I displayed two kinds of alert: First, alert with button which will be displayed when an error is encountered or to display an information message. Second is an alert without button which will be displayed like a progress message.
Here is the sample code:
private var alert: UIAlertController? // global declaration
private func showProgressMessage(sender viewController: UIViewController, message alertMessage: String){DispatchQueue.main.async{self.alert= UIAlertController(title: "", message: alertMessage, preferredStyle: .alert)viewController.present(self.alert!, animated: true, completion: nil)}}
private func showAlertMessage(sender viewController: UIViewController, title alertTitle: String, message alertMessage: String){DispatchQueue.main.async{self.alert= UIAlertController(title: alertTitle, message: alertMessage, preferredStyle: .alert)
self.alert!.addAction(UIAlertAction(title: "OK", style: .default, handler: nil))viewController.present(self.alert!, animated: true, completion: nil)}}
private func method1(){DispatchQueue.global().async{// some code hereself.showProgressMessage(sender: self, message: "Processing...")// some code here}}
private func method2(){// some code hereself.alert!.dismiss(animated: false){self.showAlertMessage(sender: self, message: "Done")}
self.displayOtherViewController()}
private func displayOtherViewController(){self.alert?.dismiss(animated: false){if let viewController = self.storyboard?.instantiateViewController(withIdentifier: "Sample"){let view = viewController as! SampleViewController
view .modalTransitionStyle = .crossDissolve
self.present(view , animated: true, completion: nil)}}}In method2, displaying the alert again will take a few seconds to display, same with the view controller. What is the proper way to show and dismis the UIAlertController in Swift 4?
Postato : 17/02/2022 8:38 am
Edward1058
(@edward1058)
RE: Show and dismis UIAlertController in Swift 4
Posted by: @edward1058
private func method2(){// some code hereself.alert!.dismiss(animated: false){self.showAlertMessage(sender: self, message: "Done")} Dunkinrunsonyou
Any Updates?
Postato : 18/02/2022 4:50 am
