Shifting of 39mm overnight
Matthias294
(@matthias294)
Membre
Hi everyone, I have a Prusa Mk4, this is the first time it has happened to me. I was printing that 18-hour print, I made that same part before, always went well. This time, the print shifted 39mm on one axe only, at 70mm high. I looked at the G-Code and everything seemed normal. I use a USB key to print it like I always do.
It happened overnight, maybe a power issue? I have good power where I live, though, but I am trying to find out what could have happened. Aside from the shift, the rest of the print is very good. My machine printed well after, so I don't understand.
Thank you.
Publié : 26/03/2024 5:33 pm
_KaszpiR_
(@_kaszpir_)
I had that recently on Mini+ https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/print-shifted-in-one-direction-after-certain-layer/
also check in which direction the shift occured, and if the bed moved in that direction?
Publié : 26/03/2024 9:07 pm
Matthias294
(@matthias294)
Membre
RE: Shifting of 39mm overnight
Sorry it wasn’t clear, not sure which axe it is (x y z) but it was the one of the bed
Publié : 27/03/2024 3:03 am
