SD Card no read
Has anyone had the problem that the memory card can not be read? I upgraded from MK2S to MK3S, did all the tests and now it's time to print and the memory card does not read the files?
Publié : 12/07/2019 11:57 pm
RE: SD Card no read
If this happens try with a different SD card if it happens again it is most likely the LCD and SD card reader assembly if not then there may be an issue with the SD card you are using.
Publié : 28/09/2019 7:47 pm
RE: SD Card no read
Check the ribbon cables are firmly inserted at both ends. Especially if the SD reader worked before the upgrade.
Publié : 28/09/2019 10:13 pm
RE: SD Card no read
Were you able to read the same card previously? If yes, as suggested above, try checking cabling. If not, make sure the card is smaller or equal to 32 GB and formatted as FAT32.
Publié : 28/09/2019 11:12 pm
