Review: Prusament PC Blend
Seite 3 / 9
3D Printing Science
(@3d-printing-science)
RE: Review: Prusament PC Blend
Posted by: @mgruenloh
@3dprintingscience
Charles posted a pretty decent review of it.
I’m planning on finding out next weekend. I’ve got a spool of Urban gray and a spool of jet black on the way now, they should be here Wednesday. I just finished printing all the extruder/X carriage parts in Polymax PC. I’ll do the same thing next weekend using the PC blend and see how they turn out.
For reference purposes I’m using a third party PEI powder coated plate from tthheekkiinngg(it’s a v4 plate) and no glue stick of adhesion aid. All settings were stock for the Polymaker PC profile except for Grid infill at 20%, and auto cooling checked because I had some issues with some small surface area layers not solidifying before the next layer being deposited.
Great prints, yeah the review is great, i was just wondering whether he had more accurate data (like CNC kitchen).
Veröffentlicht : 09/06/2020 12:58 pm
3D Printing Science
@3dprintingscience
What sort of mechanical performance are you interested in? I'm using PC mainly for its heat handling characteristics due to the proximity of these parts to the hot end. I could have used Polymaker Polymide CoPA which is even better than PC for heat resistance but I'm not sure I'm going to need a heat resistance that high.
I would be more interested in the impact resistance (thats what PolyMax PC is known for). Yeah PolyMide CoPA is a great material, I saw the 3d printing general (youtuber) video and was amazed!
Veröffentlicht : 09/06/2020 12:59 pm
Mitglied
Posted by: @3dprintingscience
@3dprintingscience
I have to agree.  Polymide CoPA is fantastic and the heat resistance and tensile strength of Polymaker CoPA is unbelievable.
Veröffentlicht : 09/06/2020 3:35 pm
Mitglied
I found a new technique.  I apply a particular glue stick and use a plastic razor blade To wipe off excess.  The first print had a little tenuous adhesion, but second through print ten, adhere and remove much easier.
  1. UHU Glue Stick
  2. Plastic Blades and handle
Veröffentlicht : 11/06/2020 1:54 pm
IAppearMissing
(@iappearmissing)
@charles-h13
I know you mentioned the heatbed temp being an issue on the Mini, but did you ever try it?
Veröffentlicht : 15/06/2020 1:11 am
prusanewuser
(@prusanewuser)
Is it really necessary or highly recommended to replace the printer parts before printing PC Blend? So far my printer prints fine with PETG and PLA. I worry that if I replace the parts, the printer may not function as well as it is right now.
Veröffentlicht : 16/06/2020 12:45 am
prusanewuser
(@prusanewuser)
Actually if I need to print strong frames, should I go for PCB, PETG or PLA? I recall reading a study that PLA is stronger than PETG at least in that study.  What is the different between Tensile Yeild Strengh (which PCB is the best) and Impact Strength Charpy (which PETG scores better than PCB).
Veröffentlicht : 16/06/2020 12:49 am
Mitglied
I have not seen a  material as tough as PC Blend that I can print this easy.
Veröffentlicht : 16/06/2020 12:57 am
prusanewuser
(@prusanewuser)
Posted by: @charles-h13
OK. Do I need to replace the parts of my printer to do this well?
Veröffentlicht : 16/06/2020 2:04 am
Mitglied
@peter-c20
No.
Veröffentlicht : 16/06/2020 2:14 am
OBELIKS
(@obeliks)
Mitglied
I printed a test piece
Good news is that the printer survived and that the piece works. The bad news is that it sticks to itself like crazy and I had to use a lot of brute force in order to get it moving. But that is also good news, parts should have good layer adhesion.
Veröffentlicht : 16/06/2020 6:38 am
Mitglied
@obeliks
Did you use a glue stick?
Try UHU glue sticks.  Rub it on the bed you need to use and then wipe off the excess with a https://www.amazon.com/FOSHIO-Scrapers-Contoured-Refillable-Application/dp/B076BBW1WM/ref=as_li_ss_tl?crid=5YSLSRN491SW&dchild=1&keywords=plastic+razor+blade+scraper&qid=1592089752&s=hi&sprefix=plastic+razor,tools,225&sr=1-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExSU5NMDFGS0JLVk9IJmVuY3J5cHRlZElkPUEwMDYwNDQzMlRGTzFGUkNRSkRaQyZlbmNyeXB0ZWRBZElkPUEwODU5MjIwMUIxWjg2TzBENURFMCZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=&linkCode=ll1&tag=chuckh1967-20&linkId=85fac25ed42c11620c5306ffc2d6b21d&language=en_U S" target="true">plastic scraper/razor blade.  I get about 6-8 print until I have to reapply.  If there are any adhesion issues on the first print, you got it too thick, but don't fret, the next one will be fine.
Veröffentlicht : 16/06/2020 10:50 am
OBELIKS
(@obeliks)
Mitglied
Yes, I used the provided glue stick.
The model is modeled so you can print it in one piece. So on the parts where there is a separation in layers it still bonded together. Usually this is not a problem on PLA or even PETG, ASA. But in this case it bonded like crazy.
Here is the layer 17 with bridging section:
https://www.thingiverse.com/thing:139268
Veröffentlicht : 16/06/2020 11:20 am
Mitglied
@obeliks
Sorry, let me try that again.  I messed that up.  I have been testing glue sticks and UHU brand so far work much  better than Kores.
Try UHU glue sticks.  Rub it on the bed you need to use and then wipe off the excess with aplastic scraper/razor blade.  I get about 6-8 print until I have to reapply.  If there are any adhesion issues on the first print, you got it too thick, but don't fret, the next one will be fine.
Veröffentlicht : 16/06/2020 12:07 pm
Printerbcn
(@printerbcn)
@obeliks
Print extruder parts.  Start with fan shrouds.  This stuff is great.  Never print without glue stick.  Consider a dedicated print sheet.
YES!
Estampación y impresiones en camisetas barcelona
Estampación Camisetas Barcelona
Veröffentlicht : 16/06/2020 12:48 pm
prusanewuser
(@prusanewuser)
@obeliks
Hi @charles-h13, for the UHU glue sticks, does it matter whether they are white or blue (with blue caps at the end)?
Veröffentlicht : 16/06/2020 3:38 pm
Mitglied
@peter-c20
I have been using blue.
Veröffentlicht : 16/06/2020 3:42 pm
prusanewuser
(@prusanewuser)
@peter-c20
Thanks. If I print white PCB, will it be discolored into blue?
Veröffentlicht : 16/06/2020 3:58 pm
Mitglied
@peter-c20
The glue is water soluble, so maybe.  I will order some what sticks and let you know if they work.
Veröffentlicht : 16/06/2020 4:47 pm
prusanewuser
(@prusanewuser)
@peter-c20
Thanks. I saw one with the word "Magic" on it. Is it the same thing?
Veröffentlicht : 16/06/2020 8:11 pm
Seite 3 / 9
