RE: Review: Duramic PETG
@mjlewis37
Try running the first layer calibration. I found I had to recalibrate when printing with Duramic PETG white. The first layer is flatter than I would like. Prusa PETA also seems more forgiving.
Ive observed Duramic is much more gobby and stringy. I'm running a .6 nozzle on a textured bed.
Thanks cwbullet, generic PETG settings in Prusa finally worked. The "trick" seemed to be washing the textured PEI plate with Dawn dishwashing detergent. After the washing I was able to get a good first layer. Before the washing I was good about wiping with 90% isopropal alcohol, but guess that wasn't enough.
The Duramic silver is opaque like Hatchbox. Duramic silver has a matt finish though, not semi-gloss like Hatchbox.
I think I've found my brand for printing my belt. Duramic is true to their advertising and it strings much less than Prusament and Hatchbox.
These belt links are a nightmare for stringing. The small channels have tons of travels in them. This pic is fresh after printing. What stringing there is easily rubbed/pulled off. I don't bother trying to clean up the channels which are only 3mm wide.
cwbullet, thanks for your review. Glad I tried Duramic.
Can you send me a link to those files? I would like to use them as a test print.
@mjlewis37
I ran into a trick last week to remove strings from PETG. If you have a gas stove, turn the burner on and lightly run the part over the flame.
A lighter won't work since the yellow flame will leave black carbon residue on the part, but a blue flame works like a charm. It doesn't get hot enough to affect the integrity of the part.
I would love to hear if anyone thinks this is a bad idea 🙂 I'm learning.
@cwbullet
Note: Been private messaging cwbullet on the .stl's.
@minimays
you can get two types of kitchen gas lighter, one has the lazy yellow flame, and the other, which is usually termed turbo, has a noisy, well defined, conical, blue flame... this second type of lighter is much easier to use
@joantabb
If my chemistry is fresh enough in my mind, the blue is also hotter.
@cwbullet
indeed Yellow is carbon rich, hence the smuts on the plastic,
Blue is oxygen rich and burns cleaner/ hotter and more directional.
It oxidises the plastic, rather than carborising it!
I have a wagner funrno 750 heat gun That go's 125 F to 1300 F lcd screen works great on the stringing paid 43.00 us at home depot.
@locktec
+1 on Wagner. Wagner is good and a decent price less than $50. You can shop around and find them cheaper but the Wagner comes with a hard case and handy concentrator tools.
Why do i see affiliate marketing links everywhere? I though a serious site ban that behaviour...
Thanks Chuck yes it does come with a hard case and handy concentrator tools. I also use it at work on Military basis drying out electronics less paper work if it works
@locktec
I did too. I am retiring from a military job in less than 2 years. I am gonna miss those "free" military cases.
So you know all about the G.S.A paper work
@locktec
Un Pocito - a small amount. If there is anything the Government is good at, it is paperwork. Creating a lot of it that is.
Does anyone know the flammability rating for this filament?
Well, I ran a scientific method and tried burning the filament with a lighter. It burned and started on fire, but would not stay on fire when I took the lighter away. 🙂
@ojref
I suspected the same. Looks like they have changed the wrapping and it looks more obvious that they are the same.
