Resin Printed Fan Shroud for MK3S+
2AHumanRight
(@2ahumanright)
I just woke up to a filament monster around my printhead that broke my fan shroud. I don't have a spare shroud, but I do have a resin printer. Is it ok to print that part out of resin with it being so close to the nozzle? I'm not sure if there is any off-gassing I should be worried about.
Best Answer by JoanTabb:
If you have petg filament, you could pint a fan shroud out of that, without a fanshroiud...
I have printed rsin fanshrouds out of prusa tough orange resin, it worked ok, but didn'y last long!
regards joan
Respondido : 20/09/2022 3:50 pm
RE: Resin Printed Fan Shroud for MK3S+
regards joan
Respondido : 20/09/2022 4:01 pm
1 les gusta
2AHumanRight
(@2ahumanright)
Ok, thank you. For future reference, what happened to your fan shroud? Was it the heat?
Respondido : 20/09/2022 4:03 pm
the fanshroud delaminated and the bottom detatched... probably the heat!
Respondido : 21/09/2022 5:38 am
1 les gusta
Thejiral
(@thejiral)
I basically copy Joan's post 😉
If the only thing missing is your fan shroud. I would just print a new one on the Prusa, without the shroud. Just print in PETG, ABS, ASA, PC-Blend or the like and do so super slow (and with 0% part cooling).
I personally can really recommend PC-Blend, if you have an enclosure. Otherwise I would go for something like TitanX, an ABS+ which prints ok and warp free even without enclosure and simply can withstand more heat than PETG. PETG is good enough for a replacement too, it just might not hold up as long at very high temperatures as the mentioned alternatives.
Esta publicación ha sido modificada el hace 3 years 2 veces por Thejiral
Respondido : 21/09/2022 6:19 am
1 les gusta
