Required feature: Sequential printing - but do all first layers.
Therevox
(@therevox)
Hey everyone,
I'm wondering why Sequential Printing doesn't also allow the option of printing the first layer of all objects first.
I've printed lots of sequential prints in a production environment, and I'm seeing a common issue that could be avoided. Normally, the first layer goes on perfect because it is laid down immediately after bed level sensing. However during a sequential print, that is only true for the first instance. The first layers of subsequent instances aren't guaranteed to adhere good because the bed shifts slightly over time because of heat. I see occasional failures,  and a lot of bad looking first layers because of this.
If the slicer had the option of laying down all of the first layers before starting sequential printing, this would fix the problem.
Edit: doing a quick google search, I see that this feature has been requested multiple times already by multiple people. One suggested the option of "print n layers first" and I think that's the most flexible solution. I also see that brims are already printed this way in sequential print mode, so the logic of that behavior should also apply to the object.
Mike
This topic was modified před 23 hours by Therevox
Napsal : 04/05/2026 1:28 am
Same Old Shane
(@same-old-shane)
Member Admin
RE: Required feature: Sequential printing - but do all first layers.
for feature requests on Prusa Slicer, it would be best to the github repository for the site, search there to see if the feature has already been requested and then if so, comment on it and if not then submit a new request
https://github.com/prusa3d/prusaslicer
Shane (AKA FromPrusa)
Napsal : 04/05/2026 9:47 am
https://github.com/prusa3d/PrusaSlicer/issues/3095
or https://github.com/prusa3d/PrusaSlicer/issues/7303
However most people want the existing behaviour of it laying down all the brims and skirts first to be changed to not do that https://github.com/prusa3d/PrusaSlicer/issues/292 which has been an open issue since 2017
Napsal : 04/05/2026 11:04 am
1 lidem se líbí
