Remote Access Printer over Network - just some idea.
Tomasz P.
(@tomasz-p-2)
I dream about the solution of remote access to the panel through the browser, reading the print status, remote control knob and maybe even switching between the access SD card between RPi Zero and the printer so as to copy to the .gcode card as fast as possible. Such a solution that would be independent of RPi Zero computing power.
If I had more time and knowledge I would try to connect to the link between RAMBO and LCD and tried to connect it parallel to RPi Zero or modify the firmware, so that it would redirect the LCD and knob-control on the USB terminal via magic .gcode command.
Just one Zero to connect them all...
Postato : 28/05/2019 9:42 pm
JMcK
 JMcK
(@jmck)
RE: Remote Access Printer over Network - just some idea.
What can you not do remotely with Octoprint?
When someone asks you if you're a god, you say, "YES!"
Postato : 29/05/2019 1:55 am
jberk_1234
(@jberkson1)
Its more expensive than the octoprint solution but what about getting a laptop to hook up to the printer and using Windows remote desktop? If you can set up the laptop to control the printer locally, remote desktop could let you control it from anywhere
Postato : 17/07/2019 12:18 am
On The Spot
(@on-the-spot)
Posted by: joe.m14
If you are doing a single color print with an MMU2s/Mk3s the LCD will prompt for which filament to use, and there is no way to select it from OctoPrint. If I start a print job directly from PrusaSlicer 2.0 or from the OctoPrint web interface, the printer will pre-heat the nozzle and bed for the job and then just sit there and wait. It will not start bed leveling or anything else - even if I already have filament at the extruder until that selection is made.
Postato : 17/07/2019 4:36 am
craftedtherapy
(@craftedtherapy)
@michael-j36
OctoPrint has a plugin called MMU2 Select Filament that works... still not 100% but lets me select the filament (1-5) from within OctoPrint from my computer.
Postato : 14/04/2020 3:38 pm
Peter in Katy
(@peter-in-katy)
Posted by: @michael-j36
Posted by: joe.m14
You can change the gcode to eliminate that question.  Change the T? to T[0-4].
Change, save, upload!
Postato : 17/04/2020 5:06 pm
1 persone hanno apprezzato
