Purge Volume (MMU)
Paul Meyer
(@paul-meyer-2)
Purge Volume (MMU)
Hello everyone. I'm annoyed because I'm trying to print a multi-colored part with my Kobra II. The layer change, all that, it's going great. But now I have a problem, I have a small part to print (a key ring) and when changing color it's catastrophic because I go from black to white. You can easily imagine what happens to me, the white comes out gray. I went to look in the help and saw that we could adjust the purge volume. ( https://help.prusa3d.com/article/purging-volumes-mmu_125097) Well already I had to struggle to understand that I had to configure several "virtual" extruders to benefit from the MMU and be able to adjust it. On the other hand, in the help it is indicated that we could use personalized parameters specific to the project. And now I'm stuck, I can't get the famous window to appear. Can someone help me?
Publié : 26/07/2024 6:36 pm
RE: Purge Volume (MMU)
Hi Paul,
Try Here
Joan
Publié : 26/07/2024 8:11 pm
Paul Meyer
(@paul-meyer-2)
Hi Joan, thank you for the answer, i finaly found the solution.
The problem was not here (i've already checks this option).
I've identified the problem but i've not found the complete solution.
Here, there must be an option. This option doesn"t always appear. I'v obtain one time but i don't  found it again.
Why and when this option appear ? I don"t know.
Publié : 27/07/2024 5:15 pm
