PSU-Einsy power panic cable
prusanewuser
(@prusanewuser)
Hi, I plan to make the cables between the PSU and the printer longer as it is very difficult to do maintenance on the printer while it is inside an enclosure. What is the PSU-Einsy Power Panic cable for?  Is it really true that we don't need this cable for the printer to function well?
Opublikowany : 30/01/2021 2:58 pm
Robin
(@robin)
RE: PSU-Einsy power panic cable
As the name suggests the cable supports the power panic feature of you printer. No power panic cable means no power panic in case of black out. Besides that, the printer works without it.
Opublikowany : 31/01/2021 10:13 am
prusanewuser polubić
prusanewuser
(@prusanewuser)
Thanks
Opublikowany : 01/02/2021 2:01 pm
@robin
I can confirm this.  The printer will work without it.
Opublikowany : 01/02/2021 2:16 pm
prusanewuser
(@prusanewuser)
Thanks
Opublikowany : 01/02/2021 2:55 pm
prusanewuser
(@prusanewuser)
Hi, if I want to make a longer power panic cable, what adapter and pins do I need?
Opublikowany : 18/02/2021 9:00 pm
