Prusaslicer Perimeter Space
Kotaztrafee
(@kotaztrafee)
As you can see there is space between the two outer perimeters which are an overhang. I need these perimeters to touch each other or even overlap. I have tried every setting I can think of so either I haven't found the proper setting or this is not able to be overridden.
Best Answer by Kotaztrafee:
Imagine that! With "Thick Bridges" on the perimeters get thinner.
So, Thick Bridges was the problem. This explains why I did not see this problem before. I forgot that I checked Thick Bridges.
Weird isn't it? Why would Thick Bridges be thinner?
Napsal : 10/08/2025 4:23 pm
Kotaztrafee
(@kotaztrafee)
RE: Prusaslicer Perimeter Space
Napsal : 10/08/2025 4:44 pm
1 lidem se líbí
