PrusaSlicer 2.0 - Need to extrude more on Horizontal Shells - Solid Layers
federico
(@federico)
Hi.
I use the new PrusaSlicer 2.0.
It is a superior product compared to previous Slic3r versions.
I guess that the new PrusaSlicer 2.0 needs a special part in this forum.
Is a MASTER PIECE !!!
That sayed, here is my question.
I print with Colorfabb HT filament. I can't find how to extrude a little more filament while it is printing TOP and BOTTOM Layers. The walls look to seal well, but tops and bottoms are not sealing.
Any idea on how can I tweak that setting?
Thanks
Respondido : 16/07/2019 2:06 pm
RE: PrusaSlicer 2.0 - Need to extrude more on Horizontal Shells - Solid Layers
Under Print Settings:Layers and Perimeters, change Top and Bottom Layers to a different value..
Respondido : 16/07/2019 6:08 pm
Peter M
(@peter-m)
Extrusion multiplier maybe?
Print a little hotter?
Respondido : 16/07/2019 7:01 pm
Or if it isn't thickness,  it might be infill/perimeter overlap if there are spaces between extrusions on a single layer.  If the underextrusion is not just the edges, usually, it is enough to measure the filament you are using and input that value into Plicer Filament diameter setting.  This adjusts filament flow.   You can do an easy test by changing Flow in the Tune menu from 95% to see the effect.
But, if everything is off, sometimes a full extrusion multiplier cal needs to be done. Extrude 100mm of filament, measure how much was actually extruded, adjust that cal factor.  That process is a bit more in depth and you should do some research for ways to accomplish the adjustment and maintain accuracy.
Respondido : 16/07/2019 7:19 pm
federico
(@federico)
Posted by: Tim
Thanks for the answer, but I am not looking to do more layers. I am looking to extrude more filament on those only.
Respondido : 17/07/2019 12:17 am
federico
(@federico)
Posted by: peter.m26
I tried those and it has improved a lot !! Thanks.
Respondido : 17/07/2019 12:19 am
federico
(@federico)
Posted by: Tim
I Nailed It!
With this last advice I was able to do a complete sealed figure.
- 175 degres on filament
- 1.05 on extrusion multiplier
- 50% on infill/perimeter overlap
Thanks guys !!
Respondido : 17/07/2019 12:31 am
What about the ensure vertical shell thickness option ? Under print settings>layers and perimeters.  Its an option that makes the shell thicker on sloping walls.  Id try that before messing with extrusion multipliers and the others as that will effect the print globally.
Respondido : 17/07/2019 7:54 am
Texy
 Texy
(@texy)
For the benefit of other, it would be useful if you could post photo's of before, and after.....
Texy
Respondido : 17/07/2019 7:55 am
federico
(@federico)
Posted by: Neophyl
I will try that too. Thanks
Respondido : 18/07/2019 8:52 am
federico
(@federico)
Posted by: Texy
Texy
That sounds fair. But to be honest there is not much visual thing you can see here. My test to see if it seals is very rustic. I print a part and just blow with my mouth through it (like a whistle). If air goes through is not good for me.
Respondido : 18/07/2019 9:15 am
