prusa slicer user data on another computer
Beebad
(@beebad)
i usually work on a MAC but started working on my Windows Box downstairs where the printer is located. I installed fusion and the Prusa slicer. I logged in to Prusa and opened the slicer. I expected to see the filaments I use on my MBP follow me wherever I opened the Slicer. Is there any way to have this happen?
thanks in advance
Posted : 09/10/2025 2:26 am
Ellen261Rister
(@ellen261rister)
RE: prusa slicer user data on another computer
PrusaSlicer does not automatically sync your custom profiles, including filament settings, across different computers (like your Mac and Windows PC) when you log into your Prusa account. To transfer your filaments, you need to manually copy the configuration files. Simply navigate to the PrusaSlicer configuration folder on your Mac (~/Library/Application Support/PrusaSlicer), find the files (specifically filament.ini), and copy them to the corresponding folder on your Windows PC (%APPDATA%\PrusaSlicer). After restarting the Slicer on Windows, your custom filaments should appear.
Posted : 09/10/2025 5:21 am
JP Guitars
(@jp-guitars)
You could probably use a file sharing app such as dropbox to copy the relevant files back and forth, I do that with info for my CNC. On the windows PC the relevant files are in sub directories under C:\Users\YourNane\AppData\Roaming\PrusaSlicer but I've no idea where they would be on a Mac and you would need to check they were the same format on both
Posted : 09/10/2025 8:09 am
