Prusa Slicer 2.9.1 Sequential Printing Bug(?)
miami573
(@miami573)
Miembro
When choosing sequential printing, we used to have two options. One for print height and one for print perimeter. These appeared on the print plate view and were extremely helpful when arranging items so that the carriage doesn't collide. Some people use a carriage with modified cooling ducts, which make them larger than the stock Prusa print carriage, which made setting the perimeter extremely helpful. These two options seem to be missing from 2.9.1. I can only assume this is a bug, because why would you voluntarily remove something that is extremely helpful and useful and could only cause unforeseen problems if it were removed? Maybe the height and perimeter should be added back to prusa slicer, as they should not have been removed in the first place? Unless them not being under the sequential printing section of the output tab is indeed a bug?
Lowes Kids Workshop
Respondido : 10/04/2025 8:52 am
RE: Prusa Slicer 2.9.1 Sequential Printing Bug(?)
Maybe you should read either the existing posts regarding this here on the forum (for example a post in this very forum, about 12 posts currently below this one https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/prusa-slicer-2-9-1-sequential-printing-bug/) or possibly the software release notes, located here https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.9.1-alpha1   .
The settings were not REmoved, the were MOVED.  To under the Printer Settings.
What has been removed and already has several bug reports made against it is the visualisation of the clearances produced by those settings.  The currently open issue regarding this is  https://github.com/prusa3d/PrusaSlicer/issues/14240
Respondido : 10/04/2025 5:33 pm
