Prusa Slicer 2. 7 3 Error Parsing config file.
I recently installed the latest Prusa Slicer 2. 7 3 version and now the program will not open.
I keep getting the same error message box after completely removing Prusa Slicer and reinstalling.
"Error parsing PrusaSlicer config file, it is probably corrupted. Try to manually delete the file to recover from the error. Your user profiles will not be affected."
C:\Users\XXXX\AppData\Roaming\PrusaSlicer.ini
The configuration file contains null characters.
Anyone else getting this error message and figured out how to fix it?
RE: Prusa Slicer 2. 7 3 Error Parsing config file.
Dennis, I'm have the same problem that you had with the recent version release 2.9.2. Did you ever figure out what the problem was or how to fix it? Thanks
Hi Vincent,
Dennis posted once, two years ago,
He may not answer
the current version of prusa slicer, is 2.9.4
you may be best updating and seeing if the problem persists.
https://www.prusa3d.com/page/prusaslicer_424/
I actually just reinstalled and cleared my cache and that seemed to fix the issue but thanks for the suggestion. Have a good one!
