Prusa SL1 resin supported temp after cure
- Hello guys ,
- Do you know what temperature Prusa resin can outstand after curing ? Thank you .
Publié : 11/12/2020 2:02 pm
RE: Prusa SL1 resin supported temp after cure
Your looking for the "Heat Deflection Temperature" which is listed in the data sheets for the resins that have them. For the "Tough" resins in the Prusa store it looks to be ~40C and the "ABS like" seems to be ~50C.
Publié : 11/12/2020 6:28 pm
- Hello guys ,
Majority of affordable resins don't have high "Heat deflection temperature", but don't forget that you can mix resins and modify properties, in your case with High Temp resins (eg. Siraya Tech Sculpt)
Publié : 15/12/2020 8:25 pm
