prusa satin sheet not sticking
Berne
(@berne)
I have a satin sheet, and it has been wonderful until now:/
i have print some stuff and it works like charm, to day i start a print and it wont stick, i have cleand it using sopa, and ipa but still it not stick. I havet change any thing sense my last working print. i have allso trying to flip it but same reslut. have the same profil as my working print
What can be wrong is the sheet done? need to buy a new one, it look almos new to me.
any ides?
Respondido : 10/01/2023 9:23 am
Netpackrat
(@netpackrat)
RE: prusa satin sheet not sticking
Did your smooth sheet (which is thicker) accidentally get selected in the LCD menu?
https://www.printables.com/@Netpackrat/models
Respondido : 10/01/2023 9:57 am
johnlynn
(@johnlynn)
Clean with ~90% IPA when the sheet is cold. If ~90% IPA is not sufficient, clean with dishwasher soap. Do not leave the sheet wet!It has an anti-corrosion layer but is still not recommended.
Respondido : 10/01/2023 12:02 pm
That's certainly a possibility. I've done it before, and it took me forever to figure out what's going on. And even if not, I'd redo my live Z calibration anyway, because dirty sheet or wrong Live Z is the culprit in 99% of cases like this one. Could be a moving PINDA, check the screw that holds it in place. Or PINDA broken. If everything looks fine, I'd get a new sheet—you can't have too many 🙂
Respondido : 10/01/2023 12:43 pm
