Problems loading filament
Txema
(@txema)
Hello,
I've been several months printing very little with the same filament. Today I wanted to change the color, so I unloaded the filament, but when inserting the new one (same material), following error occured and the filament didn't load with the auto-load option:
https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/09/f7879aa8-pla_filament_load_error.mp4
I tried to dissable the autoload mode and do it manually, but the same problem appeared.
Do you know what the problem could be? May I have to dismount all the header and adjust something?
Thank you very much.
This topic was modified 2 years temu by Txema
Opublikowany : 12/09/2024 4:14 pm
Txema
(@txema)
RE: Problems loading filament
I have just tried again and now it doesn't make that horrible noise, but it continuous not loading the filament. I guess that I will have to disassembly the feeding mecanishm...
Opublikowany : 12/09/2024 7:14 pm
JP Guitars
(@jp-guitars)
What printer are we talking about here?
First try a different filament. If that still does not work there is a reasonable chance it is a blocked nozzle or feed tube, on the mk4 they are easy to remove and check. They are both easy checks to do before dismantling anything.
Opublikowany : 12/09/2024 7:24 pm
Txema
(@txema)
Thank you. Yes, that was the problem, the feed tube to the hotend blocked. At first I just cleaned the entrance to the feeding tube, I thought that the new filament would be able to push the filament in the feeding tube towards the hotend, but it couldn't, so I had to open all again, and I could get the feeding tube out from the hotend (I didn't know it was so easy to extract it, hehe):
Now printing 🙂
Opublikowany : 12/09/2024 9:17 pm
JP Guitars
(@jp-guitars)
Glad to be of help
Opublikowany : 12/09/2024 9:19 pm
