Printing with PA-CF
trilbytim
(@trilbytim)
Printing with PA-CF
I'm trying to print with a Carbon Fibre Polyamide (eSun ePA-CF), using a Prusa XL with an enclosure. Initially I couldn't get good enough adhesion to the bed to stop it lifting, but I've now solved that by putting down a layer of Flex (with brim) first. However, I'm getting horrible stands hanging off of my part. One side has a really nice finish the other side is covered with spaghetti! What can I try to avoid this? Is it over extruding? Is there something in retraction settings to try? I'm using a Fiberlogy Nylon PA12+CF15 preset, which doesn't have any retraction options at all checked.
Napsal : 26/08/2025 8:25 pm
RE: Printing with PA-CF
I'm having excellent results with Fiberon PA6-CF on my CoreOne. The key is to create a profile that is better suited to the exact filament you are using rather than using an existing profile which most likely won't match. Start with the filament data sheet and create your own profile. You'll need to tweak it before you get a perfect print. It gets the best adhesion with either a Nylon specific glue or a PA power coated sheet (which is what I use).
Specially though the stringing in this case is probably due to over-extrusion. Try setting the extrusion multiplier to 0.95
Napsal : 31/08/2025 5:15 pm
Artur5
(@artur5)
Apart from getting all the printing parameters tuned to your specific filament, consider that all nylons need to be free from moisture or you'll run into many problems - stringing, blobs, poor overhangs, bad adhesion., etc.
It's almost compulsory to dry the filament before printing, even if you keep it in a sealed bag with desiccant. Of course, some filaments are worse than others in this matter. Prusament PA11-CF isn't that bad but other nylons I tried were impossible to get a decent print from them without a previous intensive drying session.
If you intend to print nylon filaments on a regular basis, you need a good food dehydrator or a dedicated filament drier that reaches at least 75-80C
BTW I don't think it's a good idea to print PA filament on a layer of flex. These filaments require very different nozzle and bed temperatures. To have a good bed adhesion, follow hyiger's advice :  use a glue for nylon or, better still, a dedicated printing plate like Prusa's PA nylon powder coated.
Napsal : 31/08/2025 5:50 pm
1 lidem se líbí
Posted by: @artur5
Excellent point which I forgot to mention. Before running a nylon print I dry the filament, store it in a dry box and print directly from the dry box. I also anneal my prints in a 100C dry air oven for 10hrs. Once I do that, the prints are pretty much indestructible (within reason)
Napsal : 31/08/2025 7:18 pm
trilbytim
(@trilbytim)
Thank you for your replies, I'll try some of these.
Tim
Napsal : 01/09/2025 10:39 am
trilbytim
(@trilbytim)
It turned out to be the retraction settings that solved this. It wasn't really over-extruding, so reducing the flow didn't help, it wasn't really stringing as such, this filament just seems to want to ooze out of the nozzle when it's lifted up, so setting the retraction properties as below sorted this.
Screenshot of retraction parameters set to retract 8mm at 80mm/s
I was then able to print my parts, they contain flexible parts (the orange sections) as well as the PA-CF regions. The two filaments actually seem to work well together, the flex seems fine with the high bed temperature.
Black wheel hubs with orange tyres on a Prusa XL printer bed.
Napsal : 07/09/2025 11:16 am
1 lidem se líbí
Artur5
(@artur5)
8 mm. of retraction with a direct drive extruder  and rigid filament ?. The recommended retraction length for these extruders should be similar to the diameter of the nozzle (0.4 to 0.6mm. ).  You can go higher with flex filament, up to 2mm. maybe, but 8mm. is crazy. If you need that to get a decent print, then there's something wrong with the printer, your settings or that filament. PA-CF shouldn't ooze from the nozzle if it's in good shape (i.e. well dried ). I still suspect that you have a serious problem with moist filament  (both the PA-CF and the orange TPU ).
Napsal : 07/09/2025 5:58 pm
trilbytim
(@trilbytim)
I do have a drier, so it is well dried. It's in the dry box and the drier is turned on during the print too.
I tried 3.5mm first and that helped a lot but didn't completely cure it, so then I tried 8mm and it worked very well, maybe I could reduce it a bit, but as I've found settings that work it doesn't seem worth it. After all, at 80mm/s it only adds 0.1 seconds per retraction, so I can't see the problem.
Also I used to keep getting random filament jams with the CF filled filaments, which tended to get worse as the print progressed, like the nozzle was getting more clogged as the print progressed, maybe carbon fibres were building up in it. I'd do a cold pull with PLA to clear the nozzle between each CF print and it would always seem to start off OK but then the jams would start after a bit. It's a hardened steel E3D ObXidian High Flow nozzle, so a good one. With the new retraction settings it ran through a full 11 hours without a hiccup though.
Napsal : 08/09/2025 2:56 pm
