Printer stop printing
LuLac
(@lulac)
Miembro
Greetings
I have a problem with Prusa slicer 2.9.0 alpha1. I use the Anycubic Viper printer and it happens that the printer stops printing either at the beginning or in the middle and just stops. I tried to format the sd card and use another new one but it happens every 3 or 4 prints. Should I go back to the previous version of the slicer or is it not compatible with this printer?
Thank you
Respondido : 13/12/2024 9:24 am
2.9 is an alpha, a test version intended for experienced users to experiment with.  It is not intended for regular use.
The correct procedure is to make a full description of the problem includng the settings you used and report it on Prusa's github for the developers to examine and remedy - then revert to the regular release until, perhaps, the devs will contact you and ask you to test an update.
Respondido : 13/12/2024 11:36 pm
