Print speeds
prusanewuser
(@prusanewuser)
Print speeds
Hi, for the i3MK3S, when asked to set the default print speed to: x mm/s, where should I sent that value to in Pursa Slicer? I see there are many speed settings under Print Settings->Speed. Not sure which one I should change to modify the default print speed. Also, where can we set the X,Y,Z axes movement speeds?
Napsal : 25/01/2021 2:37 am
