        Print failed with ironing
I was printing a piece that looks basically like a box, a flat bottom and some thick walls around. I tried ironing for the first time, and apparently the ironing at the bottom of this box caused the rest of that layer to fail. The printing in the layers above that seemed good again. I was using PLA with a 0.6mm nozzle and 0.3mm layers. Is this something worth reporting to developers? Or is there anything I can try to do to fix it? I'm a complete newbie, hope this is not a useless post. Cheers!
                            Napsal : 26/06/2020 12:02 pm
                    RE: Print failed with ironing
It might be worth posting a photo of the problem layer to help people give you advice.
                            Napsal : 26/06/2020 12:09 pm
Which Kinda print you where trying to print at least take a picture to show us it would be easier to understand
                            Napsal : 26/06/2020 12:17 pm
