Print Bed Heating -Before- Nozzle (Possible?)
MotoRider42HC
(@motorider42hc)
[MK2S]
Why do the nozzle and print bed heat at the same time?  And why isn't this configurable in PrusaSlicer or Printer settings?
It makes no sense for the nozzle to sit there and heat-soak while it waits for the bed to heat up.
The bed should always heat up to temperature first, and then the nozzle should heat up.
If anyone has an easy hack I can use to fix this, please let me know!!!
Thanks, James.
Best Answer by MotoRider42HC:
Posted by: @bobstro
If you want them to heat up in sequence -- slower than simultaneously, but it works, yes -- you can probably dispense with the M104 and M140 lines.
Bobstro,
Thank you so much for your help!
I took your advice, and simplified it as much as I could.
Hopefully this video will help others who have the same question!
^_^
This topic was modified 6 years temu by MotoRider42HC
Printer: MK2S + MMU1
Opublikowany : 01/01/2020 9:15 pm
Crawlerin
(@crawlerin)
RE: Print Bed Heating -Before- Nozzle (Possible?)
I am worried that if you let bed heat first and then nozzle, people will be asking the same question - why do we have to wait so long for bed heat up first then wait for nozzle when I just want to <insert usecase> 😀 It does not take that long compared to 10 or so minutes on 12-Volt Chinese printers. If you suffer from filament oozing and dripping while nozzle stalls and waits for bed, I suggest taking a look at 2-step no-ooze starting g-code, they can be find here or on Reddit.
Faster heat up would be with direct A/C heating, but no Prusa printer has this out of the box. Maybe future MK4 or XL will feature it.
Opublikowany : 02/01/2020 12:59 am
MotoRider42HC
(@motorider42hc)
Posted by: @crawlerin
Which is exactly why I want it to be a configurable setting.
Opublikowany : 02/01/2020 2:09 am
Posted by: @motorider42hc
You can do this and more with custom startup gcode in your PrusaSlicer printer profile. Documented example with other stuff here. Lots of variations around to choose from.
Opublikowany : 02/01/2020 3:43 am
1 ludzie polubili
MotoRider42HC
(@motorider42hc)
Posted by: @bobstro
Can you please dumb-it down for people like me who hated computer programming class?  LOL.  That article goes way beyond what I need.
If i am understanding correctly, all i need to do, is add this line to the beginning of the startup code?
M140 S{first_layer_bed_temperature}
What is the "wait" command, so it waits for the temperature to be reached?
This post was modified 6 years temu 3 times by MotoRider42HC
Opublikowany : 02/01/2020 5:34 am
MotoRider42HC
(@motorider42hc)
UPDATE/REPOST, since it won't let me edit the post:
If i am understanding correctly, all i need to do, is add these two lines to the beginning of the startup code?
M190 S[first_layer_bed_temperature]
Opublikowany : 02/01/2020 5:44 am
Simplified lines to start heating both bed and nozzle together would be:
M140 S[first_layer_bed_temperature] ; set bed final temp
M104 S[first_layer_temperature] ; set extruder final temp
M109 Sfirst_layer_temperature] ; wait for extruder final temp
M190 S[first_layer_bed_temperature] ; wait for bed final temp
You still want the rest of then startup routine to mesh bed level etc.
Opublikowany : 02/01/2020 1:22 pm
1 ludzie polubili
MotoRider42HC
(@motorider42hc)
OK, so it looks like, in order to heat the bed -before- the nozzle heats, then my startup code needs to be in this order:
M109 S[first_layer_temperature] ; wait for extruder final temp
and then leave the rest of the default startup code alone...
i will try this after work tonight and see if it works!
thanks!
This post was modified 6 years temu 2 times by MotoRider42HC
Opublikowany : 02/01/2020 1:34 pm
Opublikowany : 02/01/2020 1:46 pm
Bodo
 Bodo
(@bodo)
It's also possible to heat the bed and the nozzle separately using the Octoprint interface:
Opublikowany : 02/01/2020 4:38 pm
MotoRider42HC
(@motorider42hc)
Posted by: @bobstro
Bobstro,
^_^
Opublikowany : 03/01/2020 12:15 am
Saw the video from your Reddit link.G Gladit worked for you.
Prusa has implemented the 2 step nozzle warmup in the recent Mini profiles. Many of us have done a lot of tweaking of the startup gcode to accomplish various goals. Spend some time on the examples and reading the Marlin gcode reference if you want anything more.
Opublikowany : 03/01/2020 3:01 am
1 ludzie polubili
