Poor mans 3d printed PCB
towlerg
(@towlerg)
I wonder is it's possible (I don't see why not) to print directly onto blank copper clad board? If so, is there a printable material that's reasonably resistant to ferric oxide?
Dieses Thema wurde geändert Vor 5 years von towlerg
Veröffentlicht : 28/12/2020 12:42 pm
towlerg
(@towlerg)
RE: Poor mans 3d printed PCB
Posted by: @towlerg
Added later.  How to get it off after etching?
Veröffentlicht : 28/12/2020 12:48 pm
Hooch
(@hooch)
This is just bad idea from start to finish.
If you want to do a "printed" PCB you should try LaserPrinter + Transfer paper. This is how I did it in past. Laser toner is resistant to ething process.
Veröffentlicht : 29/12/2020 12:16 pm
jsw
 jsw
(@jsw)
Years (decades) ago at my one former employer we did one-off PC boards using a Sharpie on a HP X-Y plotter, drawing directly on a bare copper-clad board.  Smartwork was the name of the program used to do the drafting and layout.  IIRC it worked best with two passes and gave a much better finished product using ammonium perchlorate in lieu of the more common ferric chloride that was used at the time.  We actually did some prototype double-sided boards this way, although for any kind of production runs it was the usual litho negatives with precise registration targets and photo-resist.
Yes, I've thought of doing a similar thing using a single layer of filament, and most any plastic should be insoluble in any common etchant.
There are some so-called conductive filaments made for doing PC boards, but IIRC the typical resistance of traces was something like a couple hundred ohms per inch.
Veröffentlicht : 30/12/2020 12:36 am
towlerg
(@towlerg)
@hooch
Probably not such a good idea if you don't own a LaserPrinter, which I do not.
Veröffentlicht : 30/12/2020 10:05 am
towlerg
(@towlerg)
@jsw
Thanks for the info. I guess the resistance of conductive filament would exclude it from almost any application. How the hell do you connect components, surely not solder!
I suspect getting the plastic off without damaging the board would be the stumbling block.
Diese r Beitrag wurde geändert Vor 5 years von towlerg
Veröffentlicht : 30/12/2020 10:09 am
Hooch
(@hooch)
@towlerg
You can get new laser printer for less then good filament roll. There is really no excuse here.
Veröffentlicht : 30/12/2020 10:43 am
towlerg
(@towlerg)
@hooch
True. I just had a dumb idea and wondered if it could work.
Veröffentlicht : 30/12/2020 11:01 am
jsw
 jsw
(@jsw)
Posted by: @towlerg
@jsw
I have no clue how you would connect components, particularly those of any significant mass, to the printed traces.
Back in the Biomed Lab days we would remove the remnants of the Sharpie resist with an acetone-soaked wipe.  Since acetone readily attacks ABS, I would suspect that one layer of ABS would be fairly easy to dissolve with acetone.
Veröffentlicht : 30/12/2020 10:57 pm
