PETG warping issues on larger prints
Aria James
(@aria-james)
Hey everyone,
I’ve been printing a few larger parts using Prusament PETG on my MK3S+, and I’m running into some consistent warping issues especially on flat, wide surfaces. I’ve made sure my bed is clean and level, and I’m using a PEI smooth sheet with glue stick as a release agent. Still, the edges start lifting after a few layers.
I'm printing at 240°C nozzle and 85°C bed, with a 0.2mm layer height. Enclosure is semi-enclosed, ambient temp around 22°C. I’ve tried slowing down the first layer and increasing bed adhesion but no luck so far.
Has anyone had luck tackling warping on large PETG prints without a full enclosure? Are there slicer tweaks or surface prep tips that work well with Prusament?
Thanks in advance!
References:
https://www.theengineeringprojects.com/2021/09/introduction-to-petg-filament.html
https://help.prusa3d.com/article/print-settings-for-prusament-petg_126525
https://all3dp.com/2/petg-printing-temperature-speed-settings/
This topic was modified 11 months temu by Aria James
Opublikowany : 21/04/2025 7:12 pm
