PET-G Thermoforming and Heat Treatment Safety
weHavetheMeats
(@wehavethemeats)
I am not sure if this is the correct place to post this, so if there is somewhere more appropriate please let me know. I am planning on using PET-G in a project similar to this 3D printed arm brace. https://www.instructables.com/3D-Pri...ization-Brace/ The manufacturing process involves submerging the 3D printed part into a pot of boiling water to heat the plastic to its glass transition temperature, then molding it around an object like a person's forearm so that as the part cools it accurately conforms to the arm's dimensions. After that I want to use my oven to heat treat the PET-G to improve its impact resistance. Before doing any of this, I want to ensure this process won't release any harmful vapors or carcinogens during manufacturing. I know PET-G is safe to print without ventilation and is considered food safe. However, is PET-G safe to thermoform and heat treat? Thank you for your help in advance.
Postato : 20/04/2021 4:40 am
Dan Rogers
(@dan-rogers)
RE: PET-G Thermoforming and Heat Treatment Safety
PETG won't out gas at the glass transition temp (around 200 --> 250 c, depending on the composition).  I don't think boiling water is going to soften PETG, it is only 100 C.
A 450 degree oven will do it.
Postato : 21/04/2021 7:14 pm
Glass transition temp for petg starts at around 75c depending on brand and from the Prusa article on annealing they reckon 90-110c is a suitable temp so boiling water is right in the sweet spot.  Pretty rough on whoever's arm you are using though 🙂
You are safe on the outgassing.  If you have printed it already then heating it up to annealing temps isn't going to do much at all.
Postato : 21/04/2021 7:38 pm
Dan Rogers
(@dan-rogers)
@neophyl
I did not know that you can't put PETG in the dishwasher (70c) - I do that all the time - and it doesn't soften or melt.  Maybe I don't understand the term glass transition.  I assumed it meant melting point.
Postato : 21/04/2021 7:54 pm
PETG won't mould unless at temperatures that are likely to cause burns/scalds.  Is it possible to take a cold mould and make a cast of the arm to mould around?  Or work with PLA, scan the tailored PLA and reprint the scan in PETG?
PETG is not going to gain much from annealing, better to design a stronger shape or a thicker part.
Natural/clear PETG will be fine.  Colours might cause problems unless you can identify the pigments and get safety data on them.
Another possibility is to make a strong outer scaffold and join it to a tough, mouldable liner; it would be worth experimenting with TPU Flex.
What are you designing?
Postato : 21/04/2021 8:17 pm
@dan-rogers
Glass transition temp is when it becomes soft but not at the melting point.  Prusa did an article on annealing here that also explains GTP  https://blog.prusaprinters.org/how-to-improve-your-3d-prints-with-annealing_31088/#:~:text=PETG%20was%20annealed%20at%20110,a%20tougher%2C%20heat%20resistant%20extruder.    but CNC Kitchen also did at least one video about it previously that was quite interesting.
Postato : 21/04/2021 9:12 pm
