PE 1.41.2 do not behave normally
vudiemphuongchi
(@vudiemphuongchi)
i'm facing some issues for a while that i never had before with slic3r.
So whenever i want to print something, i normally open slic3r, import an STL, play a bit with the settings, slice and then export to SD card or sent it to octoprint.
Opublikowany : 05/05/2019 3:06 pm
Jerry
(@jerry)
RE: PE 1.41.2 do not behave normally
soooooo?
don't use Octo print I'm tapping out.
Opublikowany : 05/05/2019 3:54 pm
Sembazuru
(@sembazuru)
Posted by: vudiemphuongchi
I don't think you've finished your post. You've described what you usually do, but seem to have forgotten to follow up with what is different and not working now.
See my (limited) designs on:
Opublikowany : 05/05/2019 9:07 pm
