Overextrusions when printing figurines and the such
Gip-Gip
(@gip-gip)
Whenever I try to print a figurine, or anything moderately detailed, about 30 minutes into the print my prusa extrudes way too much causing a raised area in the print. This later evolves to a blob and then the printer crashes a lot.
At first I thought I just had to adjust the extrusion multiplier but the test cube came out fine and even turning the multiplier down to .9 did nothing to fix it
  • Original Prusa MK3S+
  • Protopasta basic PLA
  • 0.05 layer height
  • 0.4 nozzle diameter
  • 15% infill
Napsal : 15/08/2021 3:49 pm
BogdanH
(@bogdanh)
I think you should use smaller nozzle for 0.05 & 0.07 layer height (that's why smaller nozzle exist), or you try with 0.10 layer height.
[Mini+] [MK3S+BEAR]
Napsal : 15/08/2021 3:58 pm
Low layer height
Ditto.  Larger nozzles withh create over extrusion and grinding on lower layer heights.
Posted by: @bogdanh
Napsal : 18/08/2021 10:07 am
