.obj file creating stringing after slicing (not after printing)
Hi everyone.
The black image is obj file I imported and the orange image is sliced image after slicing.
I undo fill gap but still it makes filaments that are connecting the gaps...
Is there a way I can remove this one?
I am not sure why it keeps automatically make those filaments which wasn't present before slicing.
Napsal : 20/07/2023 8:49 pm
RE: .obj file creating stringing after slicing (not after printing)
Can't really tell what's going on here. The images are too small, lack context, hard to figure out the scale & size of objects. No info about which slicer, which rev, what printer, what material, print settings, etc..
Here's a guide for info you can provide so that we can help you:
- Provide as much relevant information up front so there isn't wasted time trying to get needed information, this can include;
- Your printer model.
- Any changes from the original design / modifications.
- Slicing program used (if applicable)
- filament type and manufacture.
- the settings you are using.
- If possible, attach a .3mf file (in a .zip file) as this includes all your settings for your print job and can help techs identify any setting issue, or even attempt to print the same file to see if its a problem in the printer or the file.
- if any steps have been done on your part to try and fix the situation.
- photos or videos showing the problem you are having
Whatever you find to do with your hands, do with all your might!
Napsal : 27/07/2023 9:52 pm
