No Orange + In Gcode Preview
I am using Prusa Slicer with Anycubic Vyper printer. It prints fine but when I look at a Gcode preview the orange + icon that lets you insert code is not there. Also, the Gcode preview does not automatically show after slicing.
My profile is based on the MK3 printer. I read where that printer firmware may not support these features. Can anyone tell me which printer profile I should modify for the Vyper to gain access to these features.
Thanks, George
RE: No Orange + In Gcode Preview
@gking
Upon opening and slicing the first time during a session you will want to click in the vertical slide bar once and the (+) should appear and stay for any further slicing done during a session. If it's still not showing up, check to make sure you don't have [Sequential Printing]/Complete individual objects: Ticked
If the G-code preview is not showing after slicing you can use (Ctrl+6) to see the preview and (Ctrl+5) to return to the 3D editor, you can cycle back and forth between them by hitting the (Tab) successively. (If using mac, use the mac equivalent).
Just to clarify these instructions are for PrusaSlicer.exe not the prusa-gcodeviewer.exe, I don't own an Anycubic Vyper printer, but I don't believe the features you mention are printer dependent. If I'm wrong about this I'm sure someone can straighten me out.
Good Luck
Swiss_Cheese
The Filament Whisperer
Wow! Thanks so much Swiss_Cheese. That solved my problem.
George
